NI TestStand
C# Unable to shutdown engine correctly
I am making an automated sequence generation script in C#. My code successfully creates the sequence file, but when the program is closing out it results in an error popup that it has stopped working. I believe that the TestStand engine I generated to create the sequence file was not closed out correctly.
I have been trying to follow the steps from the support article Shutting Down the Engine, but the popup still persists. Are there any other steps I should be taking that aren't listed in this guide? I am trying to not have a TestStand interface pop up at all, just have it execute in the background. Thanks.
(1,244 Views)
There's actually a different version of this document specific to .NET: https://www.ni.com/docs/en-US/bundle/teststand/page/starting-and-shutting-down-teststand-from-a.html
It's hard to say without more details on your error, but it sounds like you're running into this:
TestStand reports object leaks—The .NET CLR uses a form of automatic memory management, which includes garbage collection to reclaim memory, that is no longer in use. When the last reference to a TestStand COM object is released, .NET places the object reference into garbage collection, and the object is finalized at a later time.
If the TestStand engine performs a shutdown before garbage collection finalizes TestStand objects, and you have the TestStand debug option Report Object Leaks enabled, TestStand reports non-finalized objects as leaks, even though the application no longer holds a reference to the objects.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(1,212 Views)
I did stumble upon that page, as well. I tried using the exact methodology described in it, but when I do it never creates my new sequence file. Here is my code, where I use a slightly modified version of the SequenceFileXMLParserClass given in the TestStand examples for my entry point method.
[STAThread]
void LaunchTSApplication()
    // Create application domain, call MainEntryPoint, and
    // cleanup before return.
    LaunchTestStandApplicationInNewDomain.LaunchProtected(
        new LaunchTestStandApplicationInNewDomain.
        MainEntryPointDelegateWithArgs(MainEntryPoint),
        null,"Sequence Generator",new LaunchTestStandApplicationInNewDomain.
        DisplayErrorMessageDelegate(DisplayErrorMessage));
// Main entry point executed in new application domain.
private void MainEntryPoint(string[] args)
    // Obtain a reference to existing Engine.
    Program._engine = new Engine();
    Program._engine.LoadTypePaletteFilesEx(
        TypeConflictHandlerTypes.ConflictHandler_Prompt, 0);
    // Launch your application here.
    // e.g., Application.Run(new MainForm());
    using (SequenceFileXMLParserClass XMLParser =
        new SequenceFileXMLParserClass(_engine, out bool cancel, "SeqFile.xml"))
        SequenceFileXMLParserClass.SequenceFileData sfd =
            XMLParser.deserializeXMLFile();
        XMLParser.buildSequenceFileFromXMLData(sfd);
        XMLParser.saveSequenceFile("NewSeqFile");
    // Engine clean up.
    Program._engine = null;
// Called if exception occurs in MainEntryPoint.
private static void DisplayErrorMessage(string caption, string message)
    // Handle error here.
    // e.g., MessageBox.Show(message, caption);
I know that newly created Sequence object should be detached from the _engine when the SequenceFileXMLParserClass is destroyed. Are there any other objects attached to the _engine object that would stop it from shutting down correctly?
(1,195 Views)
