NI TestStand
C# "Interface not supported" HRESULT: 0x80004002
Hi there.
I am trying implement a C# gui app that genreates a Sequencefile based on a text files content.
ie.  Sequence_2 12133 will create a Step and call teh "Sequence_2" with given Parameters.
When executing i get the following error. => (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
It seems that the the cast of a object is not supported ( see attached screenshot) when calling
SequenceCallModule scm = (SequenceCallModule)step.Module;
I am developing with VS 2010 on a Win 7 x86 and using Teststand 5.1 with a .NET 4.0.
I already tried to play with the "Embed Interop Types" property of the referenced assemblies with no success.
Anyone got a smart idea?
Waht does the NI support know about this?
thx
Marcos V. Bischoff
(7,116 Views)
Casting is supported, but if the module is not a sequence call module and you use a cast, you will get an error like that. It might be better if you did something more like the following:
SequenceCallModule scm = step.Module as SequenceCallModule;
if (scm)
// things you do with sequence call modules
else
// things you want to do if it's not a sequence call module.
Do not use "Embed Interop Types" with the TestStand interop assemblies. That feature does not work with enums (at least in Visual Studio 2010) and TestStand has lots of enums.
-Doug
(7,101 Views)
