NI TestStand
COMException occured.Why?
Hi all
I'm having an exceptions on all of NI TestStand 2013 User Interface examples.
The exception is "Unknown Error" of type COMException.
I have trial license.
Does someone can explain how to fix the problem?
Tnx
(4,860 Views)
First guess: Wrong active TS version.
Please verify with the version selector tool that the correct version of TS for these UIs is the active one.
Norbert
EDIT: Also possible is an incorrect registration of TS on the system. So re-activating the same TS version might solve the issue as well.
Norbert
Expert: Geometry
(4,855 Views)
Hi Norbert,
I use trial license....
Can you guide me what to check???
(4,842 Views)
What happens if you run the sequence editor? If you run the NI License manager what does it show for TestStand?
-Doug
(4,838 Views)
Hi Doug,
Please find attached print screen of the NI manager
(4,835 Views)
So does the NI Sequence Editor start properly? Please answer all questions...
Norbert
Norbert
Expert: Geometry
(4,830 Views)
