NI TestStand
CSV Report in TestStand
(2,252 Views)
The first link just says to use the Simple Text Report if you are using TestStand 2012 or newer.  The second doesn't work.  But I would just play around with the options for the Simple Text Report and see if you can get the format you want.
(2,224 Views)
