NI TestStand
CVI Custom User Interface with TestStand
Good day community, I'm new in using TestStand with Labwindows/CVI.
I've got an error using TestStand API triying to open a sequence file from an absolute path.
Further I want to use some UI Teststand controls, what is the correct way to use thems, and what I need to do to use thems.
Thank you, best regards.
(2,701 Views)
The control that is visible needs to be connected to the Application Manager. I guess it is not connected to anything ? Do not hesitate to attach a code snippet with your post, that allow other users to reproduce your issue.
A good starting point are the Example User Interfaces that are shipped with TestStand. There are proposed for 5 differents developpement languages, C++, C#, LabVIEW, LabWindows/CVI and VB .Net.
There is also ressources on the NI website :
Hope this helps,
(2,681 Views)
Hello Mathieu thanks for your repply, it was very helpul!.
Now I got a new error triying to shutdown the application manager, I attached my main code as you suggested to me:
/* Main code */
int main(int argc, char *argv[])
	int		error = 0;
	long	exitCode = 0;
	nullChk( InitCVIRTE(0, argv, 0));	// initialize CVI runtime engine
	// load the panel for the main window from the .UIR file
	errChk( gMainWindow.panel = LoadPanelEx (0, "TestExec.uir", MAINPANEL, __CVIUserHInst));
	// get ActiveX ctrl handles, register ActiveX event callbacks, and connect TestStand controls
	errChk( SetupActiveXControls());
	errChk( InstallMainCallback(MainCallback, 0, 0));
	// make a handle to engine conveniently accessible
	tsErrChk( TSUI_ApplicationMgrGetEngine(gMainWindow.applicationMgr, &errorInfo, &gMainWindow.engine));
	// start up the TestStand User Interface Components. this also logs in the user
	tsErrChk( TSUI_ApplicationMgrStart(gMainWindow.applicationMgr, &errorInfo));
	// open sequence file
	tsErrChk( TSUI_ApplicationMgrOpenSequenceFile(gMainWindow.applicationMgr, &errorInfo, ".\\sequences\\callingStringStdOut.seq", &file));
	// entrypoint execution
	tsErrChk( TSUI_SequenceFileViewMgrGetExecutionEntryPoints(gMainWindow.sequenceFileViewMgr, &errorInfo, &EntryPoints));
	tsErrChk( TSUI_EntryPointsGetItem(EntryPoints, &errorInfo, CA_VariantULong(0), &EntryPoint));
	tsErrChk( TSUI_EntryPointRun(EntryPoint, &errorInfo, CA_DEFAULT_VAL, &EntryPointExecution));
	// display window and process user input until application exits
	errChk( DisplayPanel(gMainWindow.panel));
	errChk( RunUserInterface());
	errChk( TSUI_ApplicationMgrGetExitCode(gMainWindow.applicationMgr, &errorInfo, &exitCode));
Error: if (gMainWindow.panel > 0) DiscardPanel(gMainWindow.panel); DisplayError(error); return exitCode; } /*Close application */ static int ExitApplication(void) { int error = 0; VBOOL canExitNow; tsErrChk( TSUI_ApplicationMgrShutdown(gMainWindow.applicationMgr, &errorInfo, &canExitNow)); if (canExitNow) QuitUserInterface(0); Error: DisplayError(error); return canExitNow ? TRUE : FALSE; }
This message occurs when I close my application:
References to PropertyObjects were not released properly.
    Total number of objects: 4274
    Number of top-level objects: 91
    Note: Some top-level objects may be included if they are referenced by
    an incorrectly released top-level object. For example, an unreleased
    SequenceContext object references a SequenceFile object.
    The following top-level objects were not released:
        Executions [1 object(s) not released]
        Files [1 object(s) not released]
            SequenceFile #1:
                Path: c:\Users\Emmanuel.VECRANDD04\OneDrive\OneDrive - Vectralis\Escritorio\TestStand UI\sequences\callingStringStdOut.seq
        Type Definitions [27 object(s) not released]
            Type Definition #1:
            Type Definition #2:
            Type Definition #3:
            Type Definition #4:
            Type Definition #5:
            Type Definition #6:
            Type Definition #7:
            Type Definition #8:
            Type Definition #9:
            Type Definition #10:
            Type Definition #11:
            Type Definition #12:
            Type Definition #13:
            Type Definition #14:
            Type Definition #15:
            Type Definition #16:
            Type Definition #17:
            Type Definition #18:
            Type Definition #19:
            Type Definition #20:
            Type Definition #21:
            Type Definition #22:
            Type Definition #23:
            Type Definition #24:
            Type Definition #25:
            Type Definition #26:
            Type Definition #27:
        PropertyObjects [59 object(s) not released]
            PropertyObject #1:
                Type: Number
                Value: 0
            PropertyObject #2:
                Type: Array of Containers
            PropertyObject #3:
                Type: Number
                Value: 6
            PropertyObject #4:
                Type: Boolean
                Value: False
            PropertyObject #5:
                Type: String
                Value: "Passed"
            PropertyObject #6:
                Type: String
                Value: "Step.Result.PassFail"
            PropertyObject #7:
                Type: Obj
            PropertyObject #8:
                Type: String
                Value: ""
            PropertyObject #9:
                Type: String
                Value: "NUMERIC_LIMIT_DESCRIPTION_NAME"
            PropertyObject #10:
                Type: String
                Value: ""
            PropertyObject #11:
                Type: String
                Value: ",  "
            PropertyObject #12:
                Type: String
                Value: ""
            PropertyObject #13:
                Type: String
                Value: "NI_STEPTYPES"
            PropertyObject #14:
                Type: String
                Value: "NI_SUBSTEPS"
            PropertyObject #15:
                Type: String
                Value: "_EX"
            PropertyObject #16:
                Type: String
                Value: "%hs"
            PropertyObject #17:
                Type: String
                Value: ", numLimTest(Step.Result.Numeric)
[Module: c:\Users\Emmanuel.VE..."
            PropertyObject #18:
                Type: String
            PropertyObject #19:
                Type: String
                Value: "PASSFAIL_DESCRIPTION_NAME"
            PropertyObject #20:
                Type: String
                Value: "%hi"
            PropertyObject #21:
                Type: String
                Value: "+"
            PropertyObject #22:
                Type: String
                Value: "%ls"
            PropertyObject #23:
                Type: Number
                Value: 0
            PropertyObject #24:
                Type: Number
                Value: 0
            PropertyObject #25:
                Type: String
                Value: "%low"
            PropertyObject #26:
                Type: String
                Value: ""
            PropertyObject #27:
                Type: String
                Value: "-"
            PropertyObject #28:
                Type: String
                Value: ""
            PropertyObject #29:
                Type: String
                Value: "percentage"
            PropertyObject #30:
                Type: String
                Value: ""
            PropertyObject #31:
                Type: String
                Value: "numLimTest(Step.Result.Numeric)
[Module: c:\Users\Emmanuel.VECR..."
            PropertyObject #32:
                Type: String
                Value: "%tre"
            PropertyObject #33:
                Type: String
                Value: "%nom"
            PropertyObject #34:
                Type: String
                Value: ""
            PropertyObject #35:
                Type: String
                Value: "%"
            PropertyObject #36:
                Type: String
                Value: ""
            PropertyObject #37:
                Type: String
                Value: ""
            PropertyObject #38:
                Type: Boolean
                Value: False
            PropertyObject #39:
                Type: Number
                Value: 0
            PropertyObject #40:
                Type: String
                Value: "Step.Result.Numeric"
            PropertyObject #41:
                Type: Boolean
                Value: True
            PropertyObject #42:
                Type: Boolean
                Value: False
            PropertyObject #43:
                Type: String
                Value: ""
            PropertyObject #44:
                Type: String
                Value: "passFailTest(Step.Result.PassFail)
[Module: c:\Users\Emmanuel.V..."
            PropertyObject #45:
                Type: String
                Value: ",  passFailTest(Step.Result.PassFail)
[Module: c:\Users\Emmanue..."
            PropertyObject #46:
            PropertyObject #47:
                Type: String
                Value: ""
            PropertyObject #48:
                Type: String
                Value: ""
            PropertyObject #49:
                Type: String
                Value: """"
            PropertyObject #50:
                Type: String
            PropertyObject #51:
                Type: String
                Value: "outString(Locals.getString)
[Module: c:\Users\Emmanuel.VECRANDD..."
            PropertyObject #52:
                Type: String
                Value: ""
            PropertyObject #53:
                Type: Boolean
                Value: False
            PropertyObject #54:
                Type: String
                Value: "ACTION_DESCRIPTION_NAME"
            PropertyObject #55:
                Type: String
                Value: ""
            PropertyObject #56:
                Type: String
                Value: ",  outString(Locals.getString)
[Module: c:\Users\Emmanuel.VECRA..."
            PropertyObject #57:
                Type: String
                Value: "{"
            PropertyObject #58:
                Type: String
                Value: "}, "
            PropertyObject #59:
        And the following uncategorized objects:
            Report
            EditArgs
            TypeUsageList
Again, thank you very much.
Best Regards.
(2,634 Views)
