NI TestStand
CVI DLL and Sequence Context Object
I am trying to figure out if there is a way to access the sequence context of a runnning thread from a CVI Module without the sequence context reference being passed into it?
For example if I want to use a DLL module and call a function : RFGetLosses (param1,param2,&param3) can I use sequence context within that function to access Test Stand objects without one of the parameters being a reference to Sequence Context.
I hope the question makes sense!?
Steve
(3,667 Views)
Hi Steve! I may be misunderstanding your question, but are you asking if you can access objects within the sequence context of a separate step from inside of a CVI DLL function?
(3,637 Views)
