NI TestStand
CVI Operator Interface Title Bar
I’m in the process of modifying the TestStand 3.5 CVI Operator Interface (using CVI 8.0.1).  I’m looking to provide the user with as little functionality as possible and in doing this I’m attempting to remove the title bar from the main window.
My problem comes at the end of the execution when the results tab is displayed.  As soon as I click the Results Tab (with the title bar of the main panel hidden) the execution of the operator interface freezes.  When the title bar is set to be visible I have no problem.  This also occurs with the ‘out the box’ CVI operator interface.
Any ideas on how to resolve this problem would be greatly received.
Thanks in advance,
James.
(3,176 Views)
James,
Does this problem happen when you simply click on the tab, or must you click on the ReportView control?
There is a known issue with OIs without Title Bars when using a ReportView control.  Unfortunately, there is no workaround at the present time.
Allen P.
NI
(3,167 Views)
Allen,
The problem occurs when I click on the ReportView control (scrolling for example).
Does NI have any plans to release a fix for this issue?
James
(3,153 Views)
