NI TestStand
CVI Run time engine installation
We are using TestStand extensively and in our installation package will be
installing the CVI RTE (run-time engine). Where can I find exactly which
files (DLL's especially) are installed by the CVI RTE setup.exe?
Iain
(4,894 Views)
Iain,
The CVI RTE installer installs CVIRT.dll and CVIRTE.dll in your Windows\System
directory (Win98/95) or Windows\System32 directory (Win2000/NT). It also
creates a CVIRTE directory in the same.
You can get the latest CVI RTE installer from ftp://ftp.ni.com/support/labwindows/
It consists of 2 floppy disks.
By default, the TestStand 1.0.x engine installer utility will install the
CVI 5.0.1 RTE. You can have the TS engine installer install the latest CVI
RTE by replacing the CVIRTE directory in your TestStand\Setup\Engine\ directory
*before* running the TS Engine Installation Wizard.
Hope this helps,
Paul
"Iain Simpson" wrote:
>>Hi,>>We are using TestStand extensively and in our installation package
will be>installing the CVI RTE (run-ti
which>files (DLL's especially) are installed by the CVI RTE setup.exe?>>Iain
(4,894 Views)
Thanks for the reply but how about the following DLLs which are required at
run-time:
cviauto.dll
cvidbgi.dll
instrsup.dll
Iain
(4,894 Views)
Iain,
The TestStand engine installer installs CVIAuto.dll, but not the other 2
DLLs. You'll need to explicitely install those.
Paul
at>run-time:>cviauto.dll>cvidbgi.dll>instrsup.dll>>Iain>
(4,894 Views)
