NI TestStand
Calculating expressions with values obtained in a step
How to aquire a value from a step, calculate the value with an expression and use the new calculated value to compare another value aquired in another step
(2,816 Views)
There are a few steps included in implementing your issue.
1) Return a value from a code module as an output or a return value (depending on what adapter you are using) and store this in a local variable.
2) Run your calculation on the variable in either the Post Expression of the previous step or in a separate Statement step and store this in another local variable.
3) Call another code module to return the second value and store this in a local variable.
4) Call another code module to compare the two locals variables or use a statement step to compare them.
Hope this helps you in your applications.
Caroline
Natioanl Instruments
Caroline Tipton
Data Management Product Manager
(2,796 Views)
