NI TestStand
Calibrations
I'm using NI TB-4330, Do I need calibrations for that?
(2,607 Views)
The TB-4330 is a terminal block and does not get calibrated.  I assume you're also using the PXIe-4330, which does have a calibration interval of 1 year.
(2,431 Views)
We do have both but I do not know much details about calibrations.
Thank you!
(2,422 Views)
Not sure what you're looking for, but this is the calibration procedure.
http://zone.ni.com/reference/en-XX/help/374564P-01/calexec/procedure_433x/
(2,415 Views)
I just wanted to know if I need to calibrate it or not. I saw the file describing calibrations and I was not sure if I need to perform it or not.
Thank you!
(2,388 Views)
