NI TestStand
Call Executable Step with Windows Shortcut/.lnk file
Is it possible to call a Windows shortcut from TestStand?
I have a shortcut in the same location on different systems, but with different command line options specific to the system so I need to run the application from the shortcut. I tried using a call executable step, but whenever I try to use a shortcut/.lnk file, it adds the executable that the shortcut points to instead.
(2,632 Views)
Hi cjohnson963,
One option would be to use a batch file instead of that shortcut. You can use a Call Executable step on that .bat file which includes your options and it should execute as you are expecting.
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(2,574 Views)
