NI TestStand
Call Executable fails "-17500 requested operation requires elevation"
Running under windows 10, Teststand sequence trying to Call Executable to run a small exe program, but TestStand bombs out before even running the program. Error code -17500, "The requested operation requires elevation."
I know this exe program needs to be "run as" Administrator to function correctly, however in this case, the exe isn't even getting a chance to run.
(3,715 Views)
You can run the TestStand itself in admin mode.
Ravi Shrigiri
(3,682 Views)
