NI TestStand
Call Executable for tasklist
I am trying to programmatically check to see if a program is running and then save that result to a file to do some post processing on. I can get this to work via the command line (cmd.exe). If I issue the command tasklist | Find "svchost.exe" > fg.txt it checks to see if that process is running and places the results into a fg.txt file. I try to use this concept thru the call executable in test stand and although it seems to run nothing gets written to the file. Here is a snippet of that code any help would be appreciated.
(1,397 Views)
the file pathname is correct in the above snippet. It should be going to cmd.exe it was appended accidentally when I was doing the snippet.
(1,396 Views)
So the issue is with the argument expression but not sure the issue..
(1,368 Views)
How about using the .net version?
(1,360 Views)
Thanks for your help. I tried what you suggested and it works great. Is there a .net call where I can also start a program that is on the hard drive if I give it the path of the program that I want to open? I would like to do everything in .net if possible.
(1,348 Views)
You may wanna look into
https://learn.microsoft.com/de-de/dotnet/api/system.diagnostics.process.start?view=netframework-4.8
and
https://learn.microsoft.com/de-de/dotnet/api/system.diagnostics.processstartinfo?view=netframework-4...
in case you are usually doing LabVIEW programming, you might find the following thread helpful picture-wise
(1,339 Views)
