NI TestStand
Call Executable to return string with NULL (\00) values
I need to call CLI from TS. The response is a string containing NULL (\00) characters. TS cuts the response where the NULL is. In general, TS does not allow you to have NULL in the string, so how to deal with this limitation?
If I call CLI from LV I have "AAAA\00BBBB".
If I call CLI from TS I have "AAAA".
How can I configure Call Executable step to return a complete response?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,297 Views)
Hi bienieck
Check this out.
Regards
Steve
(1,286 Views)
I know I can change that normally but how can I apply this to Call Executable step to read std out?
Michał Bieńkowski
CLA, CTA, CPI
(1,269 Views)
The only solution for Call Executable I found is to save stdout to a temp file and then use mscorlib to read it and replace NULL with space in the process (see below).
This way I don't need to create extra code for code modules.
Another option without extra code modules is to use .NET System.Diagnostics.Process.Start() (attachment). But in this case, we will get rid of Call Executable.
Michał Bieńkowski
CLA, CTA, CPI
(1,264 Views)
