NI TestStand
Call Teststand with JAVA
I'm new in this forum.
I would know if it's possible to open TestStand from JAVA.
If yes, how ?
(4,579 Views)
TestStand is built on ActiveX.  So if you can call activex from Java then you can call TestStand.
My guess is that you need some sort of COM bridge for Java that will allow it to call ActiveX objects.  Then you would create a TS engine and then use that engine handle to manipulate TestStand.
Here is a document on the object model for TestStand:
http://www.ni.com/white-paper/8301/en/
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,540 Views)
here is your kudos and thank you.
BKT
(4,526 Views)
