NI TestStand
Call VIs in LabVIEW 32-bit and 64-bit simultaneously
we forced to call some VIs in LabVIEW 32-bit due to .NET DLLs inside not being capable of 64-bit.
However we do not want to run all LabVIEW VIs in the application in 32-bit just due to those few.
The idea is to run the DLL wrapping VIs in the Runtime Engine (32-bit) and set the adapter in TestStand to 64-bit.
Everything works as expected when the adapter is set to development system 32-bit.
As soon as I change the adapter to LabVIEW development system 64-bit, many VIs from the runtime engine throw errors for unfound SubVIs / Controls, e.g.
Sequence Context.ctl. Error Cluster from Code.vi etc.
Is our attempt possible at all and has anybody encountered these issues before?
Thanks.
Stefan
Message 1 of 1
(883 Views)
