NI TestStand
Call executable - calling application in cmd
I have a Teststand sequence (2017) like following:
The goal is:
In step "Start_iperfServer_DUT1" a .exe tool is started in cmd by call execuable.
After running of next step "Start_iperfClient_DUT1", .exe tool returns the response in cmd. And the response should be saved in a parameter (use Store in Variable/Property).
But the Problem is step "Start_iperfClient_DUT1" will only be executed after step "Start_iperfServer_DUT1" finished. That means .exe tool was already closed. So the response can also not be taken.
Anyone have ideal how to solve this problem? Thanks
(1,274 Views)
(1,210 Views)
