NI TestStand
Call .net function from expression
I would like to know if it possible to call .net function from expression step.
Currently to call function from .net I'm using Action step with .NET adapter.
What I would like to do is to do the same but in expression (for example, post expression of some step). Is it possible to do it?
(3,679 Views)
No
Norbert
Expert: Geometry
(3,677 Views)
Seriously? No way to do that? Damn...
Thanks anyway 🙂
(3,674 Views)
To elaborate on this a little:
No, you cannot call .NET assemblies (or other code modules) within an expression.
There is one exception since some TestStand versions: You can call the TS API (ActiveX) within expressions. So if the purpose of your request is limited to TS API functions, the answer should have been "Yes" for up-to-date TestStand.
Little side note: Maybe you can create custom steptypes calling into the .NET assembly as "Post-Step Substep". This could provide the user of your steptype with functionality similar to what you are currently looking for.
Norbert
Norbert
Expert: Geometry
(3,666 Views)
