NI TestStand
Calling .NET with IXXAT
Hi All,
I have .NET driver for communication with our product via CAN bus using IXXAT driver.
It works fine if called from other c# classes not called from TestStand.
However, calling it from TestStand does return the following error:
Error: An exception occurred inside the call to .NET member 'GetDevices':
System.InvalidOperationException: GetEntryAssembly did not return a valid assembly reference
   at Ixxat.Vci4.VciServer.LoadServer(String assemblyloadpath)
   at Ixxat.Vci4.VciServer.Instance(String assemblyloadpath)
   at CanLibrary.Communication.GetDevices() in C:\Projects ATE\TestStand Driver\Communication.cs:line 123
   at libCan.Main.GetDevices() in C:\Projects ATE\libMantra\Class1.cs:line 14[Error Code: -2146233079, Code Module/User-defined error code. ]
Getting devices is standard IXXAT code:
IVciDeviceManager deviceManager = VciServer.Instance().DeviceManager;
devices = deviceManager.GetDeviceList();
foreach (IVciDevice device in devices)
   DebugPrint(device.Description);
Red part causes that error.
Calling others function (not related to IXXAT) work fine.
Hope anynone had such issue in the past.
Thanks!
(1,557 Views)
Please confirm if your driver is .NET Core or .NET Framework.  TestStand only supports .NET Framework. Refer to: TestStand and .NET Framework Compatibility - NI
(1,549 Views)
It is .NET Framework 4.8 and using latest TestStand version.
(1,536 Views)
Per Assembly.GetEntryAssembly Method (System.Reflection) | Microsoft Learn
"The GetEntryAssembly method can return null when a managed assembly has been loaded from an unmanaged application. For example, if an unmanaged application creates an instance of a COM component written in C#, a call to the GetEntryAssembly method from the C# component returns null, because the entry point for the process was unmanaged code rather than a managed assembly."
You have two options:
  1. If IXXAT provides a C/C++ driver use that instead and call it from a C/C++ TestStand adapter.
  2. Create a console executable application with arguments and return codes that uses the IXXAT driver.  Call the executable from a Command step from TestStand.
(1,509 Views)
My answer above was assuming that TestStand was Unmanaged, however it is a Managed application.  You could still try my suggestions to see what happens.
(1,477 Views)
I figured out how to make it working. Someone had similar issue 8 years ago with Vector device:
https://stackoverflow.com/questions/33037263/teststand-action-sequence-using-a-c-sharp-dll-cant-inst...
Works perfectly implementing that solution.
Also have to mention, that I wanted to use existing C# code as all custom processing / addressing is already there, so don't have to spend time  repeating that again.
Hope it will help others.
(1,454 Views)
