NI TestStand
Calling SequenceFilePostResultListEntry
Hi Juergen
Looking at the orignal Delete2 sequence (the sequence that is not making the callback), it looks like the result reporting is enabled.  I am running Teststand 3.1, so I there may be a difference in the versions.  However, in comparing the Delete2 and Delete5 sequences, I still cannot find an obvious difference.
Thanks again for your time,
Mike
Message 11 of 13
(1,258 Views)
An Engineer from NI just figured it out (thanks Jonathan).  The Delete2 sequence was missing the ResultsList local variable.  It looks like it is working now.  Thanks for everyones time.
Mike
Message 12 of 13
(1,254 Views)
Hi Mike,
Is your Delete5.seq now running?
I compared the two steps again. And there is a big difference in Delete5.seq reporting flag is missing . Well i am using TS 4.0 but this feature is also avialiable in TS2.0.
You will see it when doing this: Set the view to MainSequence. Select the  step "Startup Camera Core" do a right click on it.
Now select Properties. Then in the "RunOption" Tab you will see that Record Result is unchecked. In Delete2.seq there will be a check
The guy from NI is absolutely right. When doing my tests I only set a breakpoint in callback only to see if i jump into. At this time i was not
interested in reports and went to "abort all" so a never saw the report.
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 13 of 13
(1,245 Views)
