NI TestStand
Calling WPF as executable module from .NET adapter: can not see my classes
I built WPF application and try to call it from TestStand API (calling as .NET exe module).
Unfortunately, TestStand does not see my Classes. What is the issue?
More than, when i used as Class library - did not have any issues like that: i saw properly my classes
I use TestStand 2021 32 bit, Visual Studio 2019
Thank you & Best Regards
*I use LabVIEW 2018 & TestStand 2021 versions
(1,219 Views)
There are some TestStand API examples of interfacing with the .net DLL.
Please do cross check your code with the code provided in the example folder.
Ravi
(1,185 Views)
The question was other than you answered.
We know how to work with DLL, we do not know how to work with .NET executable  (not DLL)
(1,183 Views)
