NI TestStand
Calling exe build with LabView from TestStand and passing parameters to that exe???
I am not sure if this can be done and would appreciate your help.
I have build an exe of my LabView VI. I can insert this EXE in Teststand sequence. However, is there a way to pass parameters to this EXE from TestStand??
I understand that I can call the LabView VI directly from TestStand and pass parameters. However for version control and hiding source code, I would prefer calling an EXE of the VI.
Looking forward to your feedback.
-Mim
(3,231 Views)
Duplicate post. Try not to post the same question in multiple forums.
(3,228 Views)
Sorry about that.
Wasn't sure for which forum this post was more appropriate.
Thanks for your reply in the LabView forum. I am looking into it and may bug you with more questions.
Mim
(3,224 Views)
Either forum would probably have worked. I just happend to be in the LabVIEW one when I saw it and responded. When you have some doubts about which forum to post to, I would recomend you pick one and if you don't get an answer in some reasonable time frame, post again in another forum.
(3,221 Views)
