NI TestStand
Can I call a sequence using Sequence Call an "Skip" the setup/cleanup routines in the called seq?
I have several test sequences that I use during our production test.  I would like to group these individual sequences into one "overall" test sequence; however, I do not want to run setup and cleanup on the individual sequences when they are called.  Can I disable the setup and cleanup portions of the sequences that are being called?
(2,893 Views)
Can't think of anything that doesn't require modification to the sub sequences.
If you are happy to modify your sub sequences you could add a GOTO (to goto the end of SetUp or CleanUp, whichever you are in) or PreConditions to your SetUp and CleanUp steps that check for CallStackDepth.  (RunState.CallStackDepth)
Have a play with it if you are not familiar with CallStackDepth, but as a rule CallStackDepth is incremented by 1 as you enter a sub sequence (and incremented again as a further sub sequence is entered etc.etc.) and decremented by one as you exit a sub sequence.
(2,888 Views)
