NI TestStand
Can I display the Requirements in the report?
Is there a simple way of getting TestStand to display the Requirements in the report?  I could make a custom reportgen sequence if necessary, but wondered if there's an easier way - e.g. ticking a box somewhere.
The sequence files already exist - we just need to be able to verify that each step has requirements attached.  I know that the sequence file documentation includes the requirements, but some of them are programmatically generated at runtime, e.g. for multiple iterations of looped steps.  In such a case, the documentation would just show the static data of an empty string.
We don't use the Requirements Gateway, we just directly enter strings into the Step.Requirements.Links array.
Thanks very much.
(3,597 Views)
Hi Sean,
I don't think there is an option to include the requirements in the report  but if you add a SequenceFilePostStep callback you can add the requirements to the report text of each step. I have attached a sequence that does just this.
Regards
Jon B
NI UK & Ireland
(3,580 Views)
Super, that will do nicely.
Could this be added as an out-of-the-box feature to a wishlist, e.g. a tick option in the report options?
Thanks very much
-Sean.
(3,556 Views)
Hi Sean,
You can post feature requests and idea for product in the Product Suggestion Center linked bellow:
http://digital.ni.com/applications/psc.nsf/default?OpenForm
Glad you liked my solution.
Regards
Jon
(3,537 Views)
OK.  Done, ta.
(3,533 Views)
