NI TestStand
Can I instantiate an object of my own CORBA class in Test Stand?
(2,894 Views)
Rae,
I'm not very familiar with CORBA, but if you can register it as an ActiveX server, you can instantiate an object using the ActiveX step type. Otherwise you will need to instantiate the object in a .NET assembly, C/C++ dll, or LabVIEW VI. Once called from TestStand, the code module could then pass the reference to the object into TestStand.
Richard S.
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(2,862 Views)
