NI TestStand
Can I open the (.squ) sequence files using NI test stand 4.0 version?
I have the sequence files created using ATETool Kit test Executive. But I have NI 4.0 test stand. I want to open the sequence files using NI 4.0 test stand. Can i do that?
(3,727 Views)
I am not familiar with ATETool kit Test Executive, but I doubt NI TestStand will open this. As you have both, have you tried it?
TestStand does have a conversion tool for converting NI TestExecutive sequence files into TestStand sequence files.
Maybe you could write a conversion tool to make the conversion for you if you have many ATETool kit Test Executive files.
Regards
Ray Farmer
Regards
Ray Farmer
(3,722 Views)
There is a .squ file format used by the CVI Test Executive Tooklit that is able to be read into TestStand.  If you are using this format, you can use the Sequence File Converters in the Tools menu to convert the file.  If it is a file from another product, you will have to convert it in another way.
Allen P.
NI
(3,709 Views)
