NI TestStand
Can I restore defaults of a TestStand installation?
I have been playing with TestStand and exploring all that it is capable of. Now I'm ready to get started on an actual project and I'm wondering if there is an easy way to get it back to it's initial state. I have station globals, custom step types, templates, etc and I want to start clean.
Is my only choice to manually remove what I've done? TS4.01 Smiley Wink
Toby
(5,104 Views)
Hi Toby,
Thats a good question!  I have always reinstalled TS. .........And one hour later everything was clean.
I am courious what other user are doing or what Ni - guys are saying.
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,083 Views)
Accepted by topic author TobyD
If you have been working in the User folder's then just delete the contents of these folders.
Delete the cfg folder and TestStand will regenerate them using default settings.
If you have been modifying items in any of the NI folders then you will have to reinstall TestStand.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(5,072 Views)
Hi Ray,
I have removed my CFG folder. It is working perfectly!
Thank you for this useful hint
Juergen
--Signature--
(5,068 Views)
You might lose your Tools menu items though. You should keep your toolmenu.ini (in your cfg directory) otherwise you might have to repair to get it back (or copy it from another machine).
-Doug
(5,051 Views)
Thanks for the replies. This did the trick for me as well. I wasn't sure if just deleting these files would break other things so I wanted to ask before I tried it.
(5,043 Views)
