NI TestStand
Can I use C# forms with TestStand
I am looking to use a rtf file to store data collected during a TestStand sequence test.  I have used C# class libraries in the past with TestStand, but I can only alter the Rich Text while using a Rich TextBox format and that can only be used in a windows form.  Is it possible to work with a windows form and not a library with TestStand?
(3,052 Views)
Hey mcfrenzy36,
I found something in the TestStand help that I think can point you in the write direction http://zone.ni.com/reference/en-XX/help/370052J-01/tsapiref/infotopics/font_objects/
Hope this helps
BeauH
(3,036 Views)
