NI TestStand
Can Symantec's ProcommPlus code be run by TestStand ?
Can Symantec's ProcommPlus (Aspect IDE) code be run under TestStand ?
- Is there a way to port the code over to TestStand or transform it into a series of DLL files for use by TestStand ?
I understand that TestStand can run code created by any programming language ....
(3,262 Views)
The scripts cannot be called directly by TestStand. You write a script, compile it to a .wax file, and then Procomm will run it. You would need to control Procomm itself from TestStand. The only control that Procomm gives you is that it is a DDE Server. I don't think there exists a DDE step type for TestStand but many programming languages support so you could probably use a code module to give you some automation. I needed a VT100 terminal emulator program to run from TestStand and while I like Procomm, I found the DDE interface too limiting. Instead, I used a product called HyperAccess which has an ActiveX interface. Of course, if you just need some basic serial communication, there are more direct and easier methods.
(3,253 Views)
TestStand can call many different programming languages, but not all.
The languages that have adaptors are:
LabWindows/CVI
C/C++ DLL
.NET
ActiveX/COM
HTBasic
In addition, using the ActiveX adaptor you can connect to any code which has an ActiveX server interface.
Josh W. | National Instruments | Applications Engineering
Josh W.
Certified TestStand Architect
Formerly blue
(3,233 Views)
