NI TestStand
Can TestStand 3.1 have an expression (or variable) for a numeric limit in a numeric limits test?
All I see is a chance to enter constants in the high and low limits.
What about a local variable?
(4,044 Views)
This function is not possible in TestStand 3.5 or earlier.  You can use a pre-expression to set the value of a limit.  For example, Step.Limits.Low = 15 is a valid pre-expression.
Allen P
NI
(4,036 Views)
What happens with the numeric limit settings in the edit limits dialog box?
If it's a pre-expression, would they get over-written?
(4,036 Views)
The edit-time copy of your sequence remains unchagned with the constant values.  The run-time copy is updated.  Since the pre-expression always executes before the code does, it is essentially the same as having an expression for the limit.
The edit dialog box, since it only touches the edit-time copy of your sequence, will keep whatever constant values you select for it.
Allen P.
NI
(4,027 Views)
There is an example in the teststand examples folder which will allow you to use an expression in the limits file.
This maybe a be a solution for you.
Regards
Ray Farmer
Regards
Ray Farmer
(4,020 Views)
