NI TestStand
Can TestStand Sequence able to trigger labview control events?
I have to generate an event for boolean control registered in labview VI from Teststand.
I found that ActiveX functionality can do this. Can someone help me out with this?
(1,265 Views)
You may put an action step and call LV vi which generates the event for the one which has the boolean control.
(1,103 Views)
