01-11-2013 11:02 AM
All,
Can a seq developed on 2.0 be run on a 4.1?
I did load it on 4.1 and the sequences all shows up, but before I spend time tweeking anything tht is missing, would it work?
thanks
Solved! Go to Solution.
01-12-2013 01:23 PM
Yes, it should. There are a few incompatabilities that are all documented. I load and run TestStand 2.0 sequences just about every day and it works.
Jim
01-12-2013 02:49 PM
But if you save it under 4.1, can it be opened again under 2.0?
01-13-2013 07:29 AM
No. It is a good idea to keep your SeqFile(s) created in TS2.0 in a save place.
I currently do not have access to TS4.1 and cannot check if the menu item "Save As ..." allows to write TS 2.0 SeqFiles. In TestStand 2012 "Save As ..." allows for down to TestStand 3.0.
01-13-2013 11:44 AM
Yes, you should be able to 'Save As..' to TestStand 2.0 from TestStand 4.1.
Jim
01-14-2013 02:52 PM
I tried the "save as" but unlike LabView there was no option for saving in a previous version.
01-14-2013 02:59 PM
There is a drop down box in the 'Save As' dialog that is named 'Files of Type'. Under there there should be an option to save as "TestStand 2.0 Sequence File (*.seq)".
Jim
01-14-2013 04:31 PM
I now see that, thank-you very much Jim.
