NI TestStand
Can anybody give me parameter description of function "TS_EngineGetSeqFile"?
can anbody tell me where I can find documentation and a description of the parameters of the function "TS_EngineGetSeqFile"
regards samuel
(2,886 Views)
The function “TS_EngineGetSeqFile” is used by CVI.
To see the function, open an example project in CVI.
It’s located in the following directory:
C:\Programme\National Instruments\TestStand x.x\UserInterfaces\NI\Simple\CVI\TestExec.prj.
The function in CVI is located under:
NI Teststand API x.x -> Advanced -> Engine -> Object Access -> Obsolete -> TS_EngineGetSeqFile.
You also can use the Teststand Help. Type “GetSequenceFile” in the index tab, to search for the function.
Here you can find an extract of the Teststand help.
GetSequenceFile Method
Syntax
Engine.GetSequenceFile ( sequenceFilePath, getSeqFileFlags = GetSeqFile_OperatorInterfaceFlags)
Return Value
SequenceFile
A SequenceFile object.
Purpose
Note  This method is obsolete. Use GetSequenceFileEx instead.
Remarks
Returns the SequenceFile object for the sequence file that the sequenceFilePath parameter specifies.
Parameters
sequenceFilePath As String
[In] Specifies the pathname of the sequence file.
getSeqFileFlags As long
[In] Pass one or more GetSeqFileOptions constants. Use the bitwise-OR operator to specify multiple get sequence file flags.
This parameter has a default value of GetSeqFile_OperatorInterfaceFlags.
Kind regards
Ulrich
AE NICER
(2,859 Views)
