NI TestStand
Can i call a .vbai from TestSTAND4.2 script
Is it possible to call a .vbai from testSTAND 4.2?? I cant see any way of doing it, do i need a newer version of teststand to call a .vbai
(3,231 Views)
You can use the LV API for VBAI (introduced in VBAI 2010), and call these VIs from Test Stand to launch a local VBAI engine, open an inspection, and run it. You can find an example of this in your <Vision Builder AI directory>\API examples\TestStand Examples. There's also a video on-line to illustrate how to do this:
http://zone.ni.com/wv/app/doc/p/id/wv-2424
Hope this helps,
Brad
(3,228 Views)
Hi Brad,
I am having trouble playing the video, is the video link ok?
(3,206 Views)
It works fine for me. Make sure you have the latest Adobe Flash is my recommendation.
Brad
(3,201 Views)
