NI TestStand
Can't Fetch Results from SQL Query
Hello All,
I'm having trouble fetching results from a SQL query I run in TestStand using "Open SQL Statement".  The number of records returned is always -1.  The funny thing is that I can run the same exact query in SQL management studio and always get one record back.
I'm at a loss here.  I have attached the query, any help would be greatly appreciated.
Thank you,
Aaron
(2,147 Views)
So I rewrote the query again another way and still got a -1 back for number of records from "Open SQL Connection".  Then, I realized that both queries used SQL variables.  After removing the SQL variables, "Open SQL Connection" returns the correct number of records.
Can anyone explain why this is?
Aaron
(2,084 Views)
What do you mean by "SQL variables"?
My first response would be that TestStand does not operate with SQL variables, but since i do not really understand your question i may be wrong.
(2,043 Views)
