Hi Andrewbft,
Is this Station globals or file globals.
Is your sub-sequence contained in a seperate sequencefile.
If this is the case and its file globals, then each sequencefile has seperate file globals, by default.
You can make the sequencefile use a common file globals by selecting the properties of the sequence file. You will find a drop down control on the SequenceFile Property dialogbox which allows you change this.
Regards
Ray Farmer
Regards
Ray Farmer
