NI TestStand
Can't change Adapter from C/C++ DLL to Labview
I'm new to TestStand and I have a program that includes 8 supplier designed steps that call DLLs.  On 7 of them I can change the Adapters (under properties - General - Adapter and select from the drop down list).  I can select several different types of Adaptors including Labview.
My problem is that on 1 of them, under the Adapter list it only shows C/C++ DLL !!
I'm sure there is a setting somewhere (believe I've seen it before) that has restricted the Adaptor - I need to change it to Labview.
The step is a Property Loader (supplier designed) that uses a DLL module - it's a bit different to a regular Property Loader.
Does anyone know where this setting is that will allow me to select Labview under the Adapter?  I've already checked Configure Adaptors and that looks  fine.
Many thanks
Paul
(1,662 Views)
Accepted by topic author PaulJR72
https://zone.ni.com/reference/en-XX/help/370052AA-01/tsref/infotopics/db_step_type_prop_gen_tab/
See Designate an Adapter.
To access this dialog, right-click custom step definition and select Properties.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,650 Views)
Thank you - that was a great help! That took me to:
To access the built-in properties of a step type:
  1. Navigate to the types view using the View » Types menu, or the shortcut key Ctrl + T
  2. Right click the step type, then select Properties… to launch the properties window
(1,626 Views)
