NI TestStand
Can't load VI into TestStand
In a new action step, I can't load a call to an Agilent 34970 VI.
When I select the VI Path, the UI shows a RED "!" with the  message "LabVIEW: File not found. The file may be in a different location or deleted. ... etc."
The path the UI shows is completely wrong. Where does it get that path? How do I correct it?
(3,906 Views)
Generally this is a search directory issue.  If you go to the path it tells you is the file there?  What is the path it tells you and where should it be looking?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,886 Views)
You were right. Thanks. 🙂
(3,881 Views)
