NI TestStand
Can't write Multi-Numeric Limit Test results to Database
I'm using a custom schema and all parameters/expressions are properly mapped.
When I run my Multi-Numeric test, only the first measurement is being written to the DB. Shouldn't it perform multiple writes (per the number of measurements)?
I'm using a very simple vi with 2 data points in the measurements array and two sets of limits.
Any help is appreciated.
Thanks.
(3,244 Views)
Do you get the same result if you were to use the default schema?
Regards
Ray Farmer
Regards
Ray Farmer
(3,234 Views)
Ray,
I did what you suggested and it worked. Turns out some of the schema expressions are different from NumericLimitTest and MultiNumericLimittest.
Once I changed my expressions my schema worked fine.
Thanks.
(3,205 Views)
