NI TestStand
Cannot connect VI Output Terminal to Sequence Context
I am unable to wire an output terminal of a VI to a sequence context variable. In the Edit Labview VI Call screen on teststand the output is always set to false. The f(x) button on the right does not show for this specific output. Attached is a snapshot of the screen. The output I am interested in is boolean called End Test.
Any word on why this is happening will be appreciated.
Sam
(4,141 Views)
What version of teststand are you using, looks like an early version of TestStand.
Have you tried using an integer instead of a boolean.
Regards
Ray Farmer
Regards
Ray Farmer
(4,122 Views)
Ray,
The version I am using is 3.1. However, I will try an integer possible OR the bits on the other side.
Ayman
(4,116 Views)
I tried changing the output to number and still didnot work. I also tried swapping the two terminals, now the swapped terminal does not work. It seems that it is affecting the FIRST output terminal regardless of what control you are linking it to.
(4,114 Views)
I figured out a fix to the problem. I clicked reload prototype then hit No when asked to keep the current parameters. I do not know how that occured in the first place, but hopefully this will be a lessons learned to some one else as well.
(4,095 Views)
Thanks for posting the solution, CAN Programmer.
Cheers,
David Goldberg
Software R&D
(4,092 Views)
