NI TestStand
Cannot find ResultList
In which loop iteration does this error occur?
Message 11 of 15
(1,251 Views)
it seems like its the last iteration...I never see as I loop through the previous results until the last one. In my case, the array size is 42 and it errors on the final (43rd) result.
Message 12 of 15
(1,239 Views)
Accepted by topic author thosquanta
That’s because your main sequence will create a result Container when starting the sequence call step. No43 which is giving the error is in fact the result for your cleanup sequence 🙃
In this case, you can ignore the last element. Yet you should document this in your code: be kind to your future self (as Fab would say)
Message 13 of 15
(1,226 Views)
Allllllrighty, I'd say I am fully functional at this point.
I had some issues with using the RemoveElements() function but, since I just need to nix the last element, I just set the array size to one less than what it was and presto spaghetti-o, we're good to go.
Thanks so much for your insight, Oli_Wachno!!
I figured I could just brute force the final array element out of there, but wanted to understand why it was there first.
I have, per Fab, made some notes in my code to remind future me.
thanks again!
Message 14 of 15
(1,198 Views)
Teststand----Configure----Model Options---Discard Results.... Disable this
Message 15 of 15
(761 Views)
