NI TestStand
Capture Terminate Button Event
I'm looking for a way to capture when users press the Terminate button (toolbar or user interface) and then display a message box to ask them if they really want to terminate or ignore that and return to testing.
Curt
(1,556 Views)
I haven't tried it, but the ApplicationMgr.PreCommandExecute event looks like it would be good for this.
(1,538 Views)
If you are using LabVIEW as a Adapter you can use Termination Monitor to get the termination status.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,517 Views)
