NI TestStand
Change Message Popup title bar background color
I am running Testand 4.0, and I would like to change the background color of the Message Popup title bar to be either Green or Red. A customer wants to see a Message Popup for each test and the color would be more eye catching.
Hurst
(4,135 Views)
The title bar color is set by the Windows System preferences.  It is not possible to change the color using the Message Popup step.  If you want this kind of functionality, you will have to create a code module in the environment of your choice, such as LabVIEW or CVI.
Allen P.
NI
(4,133 Views)
I was afraid of that, since it follows the XP theme.
Hurst
(4,128 Views)
Message deleted..
Message Edited by JoeLabView on 06-12-2008 08:32 PM
(3,915 Views)
