NI TestStand
Change Numaric Format of multiple variables at the same time
Is it possible to have multiple numeric variable selected and change the numeric format on them at the same time?
I can do it individually but when I select more than 1 the numeric format choice grayed out.
I am using TestStand 2017 32bit.
Thank you
Hiren Patel
(2,207 Views)
Hi Hiren,
Could you post some screen shots of both scenarios?
Setu P.
Applications Engineering
(2,153 Views)
Please see the attached. I have variables already created. Just need to change the format. It is very time consuming if I do it 1 variable at a time. So just looking for any better way to make the format change in mass. When I select multiple variables the numeric format option gets disabled.
Thank you.
Hiren Patel
(2,129 Views)
