NI TestStand
Change Test UUTs and Single Execution Hot Keys
Is there any way to change the hot keys for Test UUTs and Single Execution? I would like to reverse them so that I can run Single Execution by pressing F5.
(3,042 Views)
By default F5 is used for the first execution entry point and Ctrl-F5 for the second. If you drag the Single Pass entry point sequence ahead of the Test UUTs entry point sequence in the process model file, it will swap their order and thus swap the hot keys.
(3,035 Views)
