NI TestStand
Change a value at runtime, but should not be saved.
Hi All.
I have made a step, where I can select/deselect some of the steps in the seq, to do that, I set skip/normal mode of the steps (RunState.Sequence.Main[XX].TS.Mode).
The problem is that if you change this value at runtime, then it remember this setting, when you get back to the seq (after execution).
Is there anyway that I can do so it will not "save" this new value...
I can of course save the old settings, and then rewrite the value in the end of the seq, but it would be nice if it could be done in one step.
Any help ???
Kind regards Thomas
(3,243 Views)
Instead of using an expression step, use an ActiveX Step type and use the method Step.SetRunModeEx ("Skip", <execution obj ref eg RunState.Execution> )  (see the help for more information)
Regards
Ray Farmer
Message Edited by Ray Farmer on 10-24-2006 01:03 PM
Regards
Ray Farmer
(3,238 Views)
Thanks Ray.
Now it works very well..... if anybody else read this... then please keep in mind that it is very important that you input a reference to the execution in the call SetRunModeEx, else it stills change the seq. file.
Kind regards Thomas
(3,233 Views)
