NI TestStand
Change database option in PreUTT seq
Hi everybody,
Is possible enable or disable data base results (located in result processing) in PreUTT seq?
I know that in main sequence i can use DataBaseOption callback to change that and it works, but i need select enable or disable in every sequence, this is the resason i want to change option in PreUTT seq of model
Message 1 of 1
(1,656 Views)
