NI TestStand
Change font size on TestStand Pop-up Msg Title
I don't see a way to change the font size on the pop-up message window title "NameOf(Step)".  Is there a property for that?
(1,765 Views)
Forgot about the context menu when you click in the Title Expression field.  You have a choice of Larger or Smaller.
Correction:
But wait that only set the TestStand IDE environment not runtime pop-up window title.
(1,754 Views)
Alternatively you can click the Ao button on the right side below section.
Ravi
(1,726 Views)
In your pic, look at the "Title Expression" - it doesn't have a font size control button "Aa".  Thus the reason for my question.  Does the property exist for Title Expression?  I didn't find that property as yet.
(1,698 Views)
Got it. My bad.
I also checked the step properties and there is no variable to store the title expression font but there is a one for message expression.
So font changing in Title expression is not supported.
Probable reason can be  that the text  needs to fit into a fixed height title bar.
Ravi
(1,693 Views)
