NI TestStand
Change label description using TestStand API
can I change the label description using TestStand API (Visual Basic)?
(2,253 Views)
If, for instance, you have a MainSequence/Main Label step named "Label", you can make a statement in another part of Main to change the description with RunState.Sequence.Main["Label"].Description = "12345" (Note that this is a TestStand step; I'm guessing there is a simple analogous VB command).  This will change the value during run time, but it will revert back by the time the sequence is complete.
Pulido Technologies LLC
(2,236 Views)
