NI TestStand
Change name of parameters output by code module
Hi guys,
I am calling this  code module everytime but pass different parameters as input  & get different results
I want to customize the  Parameter Name  for the output parameters as they get saved in my report.
& so I can be very specific.
(4,464 Views)
I think it is not an option or configuration in TestStand. You can try to change the parameter name in the code module.
Have you tried this?
best regards
Richard
(4,244 Views)
